Ignition switch recall
RudyB
Anyone hear of an ignition switch recall on 2014 spider rt due dess problems mine is in shop right now to get dess module replaced
Oh yeah....
Been a real issue here for some time now. May have gotten it solved not hearing much lately. Sorry to hear your in that spot but the new dess should get you going once again....:thumbup:
There is no recall for the ignition switch or DESS module. By the way they are not the same thing.
There is a Warranty Campaign to replace Ignition switches with a certain series of key codes on 2014 models. Reason the key will get stuck in the switch and render the Spyder inoperable. Do you have key code tag or number. If it has not happened already on your 2014 it likely never will.
There have been a high rate of DESS module failures on 2014 models and BRP will replace with a revised unit.
Recalls only have to do with SAFETY related equipments.
A faulty ignition switch is not a safety item.
AJ
​My ignition switch was replaced 14-months ago. The service manager at my dealer phoned me to say that there was a service bulletin about potential problems and that they would replace the switch under warranty. By the way, I have not had any DESS problems.
