Sorry about starting a new thread but I think the topic has transformed into a DIY idler fix-it thread.
I went out into my garage and removed the nylon roller off my BRP idler. As previously stated I'm hovering around 10,000 miles on my dealer installed BRP idler.
I felt as do many that the roller is cheap quality and two bearings should be used and I agree.....BUT.
I cleaned up my well used BRP roller and noticed stamped on the BEARING (its not a bushing!) with a magnifying glass it read " JAPAN 60601 NSK". It has one bearing located in the center and was in excellent condition, no play!. The nylon roller likewise was in excellent condition. The bolt and washers used to hold everything together are heat treated high strength steel.
I'm not bashing those looking to go two bearings as I will probably do the same BUT I found my extremely well used BRP idler to be in excellent condition. I must not lie or Santa will not bare any gifts!
I took pictures and will let you be the judge, don't beat me up for showing what I found.
