I wonder
Without a way to hack into the ECU to resolve and coordinate fuel delivery and timing issues, as well as disable possible warnings from missing signals from the deleted system portions, it would be a huge challenge. A person could go nuts trying to crack this one. JMHO
Awww c'mon you guys! Could this be tougher than getting the electronic Nanny taught some manners with the help of the engineers from Bosch?? :roflblack: Where is your sense of adventure??
Butane conversoin
Pjense,
There is on the market a conversion that uses those little butane gas lighters. It consists of mounting 144 on those lighters in their holder that presses open the little valves electrically by a wired remote control using a 9V little battery. A 1/4" tube is run to the intake of the throttle body. It's just that simple. Check out www.butanegasconvert.com/spyder
if it would be a huge deal to change my spyder over to propane and use the trunk to hold the tank?
A large percentage of the motorized equipment I work on is LP powered. We have Ford, GM, Kubota, Robin, and Kohler engines powered this way. However, a Rotax???????
propane spyder
Like everybody said, GOOD LUCK. # 1 what happens if god forbid if you were in a head on collision .
#2 My experience with fork trucks that ran on propane was it was a pain inthe A___. You have to have a bigger cooling system than is on the spyyder. The hot antifreese must make the propane warm enough so it does't freese up so it can be urned in the engine.. Propane is very cold in a tank. This is with carbureraters. Not Fuell injection.I don't know what would happen with FI.:yikes:
[from someone who has worked in the industry. nothing personal, but that is by far the dumbest idea I have ever heard , and by far the least safest of all plans for the Spyder. ( extended fuel cap etc ). JUST A BOMB WAITING TO HAPPEN AND AGAINST THE LAW AS WELL ( ventilation ):mad: DO NOT PROCEED ANY FURTHER WITH THIS THOUGHT AND OR PLAN.
