I thinkl I have bad battery connections
bcoulter19
put key in spyder turn the key everything lights up. hit the mode button and hit the starter and everything goes blank. it says its in neutral. I had it connected to tendre before I started tryin g to start. Does this sound like I might have a bad connection or what?
any help will be appreciated.
Bill
Tighten up the battery connections and try again. Is it repeatable? Jiggle the wires? A bad connection will be intermittent or sporadic depending how loose it is.
I checked the tightness fo the ground on the frame under teh seat and it seems fine. I need to get to the battery and check those. I just got it back form the shop and haven't had a chance to ride since my thumb surgery. so I will try that probably this weeeknd. It is going to be one crazy week.
How old is the battery? Is the tender reading a full charge? I've had old batteries take a charge but won't crank because they've sulfated to the point of unable to provide the cranking amperage needed. The bike lights will come on, the fuel pump energizes, but when I thumb the starter everything goes dead or the starter relay just clicks / buzzes and then goes silent. If you have a regular battery charger that has 50amp cranking mode, try jump starting the Spyder.
Bill
Check the negative terminal AT the battery, If it's lose that will cause the same symptom, If it's tight,
Then i would suspect a bad cell in the battery.
Battery is about 3 years old, but it went through one fairly cold week before i remembered to connect the tender. thats why I am thinking it is either loose connections or more likely the battery because of the cold and I didn't get it hooked up in time.
No expert here. Far from it. However, three years does seem to be just about what the natural life of a battery is. IMO
Chris
3yrs is an average. I've gotten as much as 5, to as little as 1. The one year was on a go kart starter that wasn't used regularly or charged on a battery tender.. it was a walmart special. Your battery lasts longest if not used in extreme heat or cold, is charged by the vehicle regularly or hooked up to a battery tender device. Starts in extreme heat and cold tax a battery's power.
