How to find Codes for RS
CJ/johnnyg
I have a 2011 RS SE5 can anyone tell me how to pull the codes up. I had my engine light come on today, It said to check Transmission. I checked the oil and added some oil and it went out but it came on later. I was just wondering how to fine the code # if there is any so I can tell them when it goes to the shop. Any help would be appreciated. Thanks
Take a look at reply 2, Carol. Hope this helps.
http://www.spyderlovers.com/forums/showthread.php?43927-error-codes&highlight=find+codes
This is how I check for codes on my 08 GS/RS....
1- turn the ignition switch on and start bike
2-press the Mode button repeately until engine hours (total hours) shows on the display
3-Press and hold the Mode button while pushing the "flash high beams" button on the right handgrip 5 (five) times within 2 (two) seconds!!!
4-If no active faults- NO AFC will display
5-If an AFC is present, an AlfaNumeric code will display
6-If more than 1 (one)- press mode button to cycle through.
If you have a service manual you can check in there, or you can post on SL and the :spyder2: guru's will chime in and help out.
Hope this helps... :thumbup:
thanks I will give it a try
Just a reminder that you don't have to tell the dealer. He will pull up the fault coses with BUDS, right away. In addition, he can pull up the previously occurred faults, where you can only see the active code(s).
