1330cc how to change spark plugs on 2014 rt 1330 engine
Just did a spark plug replacement on our 2014 RTS. To make it a bit easier, I raised the main upper section slightly to facilitate removing the left side airbox.
Overall, the worst part was dealing with the failing foam insulation. The foam was kind of a gooey mess, fell apart if your hand touched it. Time wise, removing the deteriorated foam took the most time, the spark plugs were easy and quick to change.
Here's the easy way. Take your bike to your dealer. Write a check, use your credit or debit card. What could be easier?
