Doc - Riverside
Another SL Member asked me if I could figure out how to install the Bluetooth Dongle on his RT when he came to the Secret Lab in early April for a visit to work on his RT. He has the CB and XM radio installed and the Bluetooth Instruction state that the CB Radio can't be installed or removed. He said he never uses the CB so come up with a way to do it. Looking at the Wire diagram for the RT connector RD0_2 is the connector that the CB and XM radio use to connect the radio. I called him back and told him that it would cost $14.00 for parts to make the required cable( 5 contacts, 7 blanking plugs, USB power cable and 3.5mm audio cable ). The 12 wires for the CB were totally removed from RD0_2 and the Bluetooth cable installed.
Trunk install is accomplished by drilling a 3/8 inch hole as shown and installing a 1/4 inch ID grommet. The contacts on the dongle cable will easily pass thru the grommet and RTV is used to return the trunk to a sealed condition. The RTV is on the backside of the grommet.
To remove the contacts you have to release the contacts
Remove the 12 Wires associated with the CB
Unused pins have plugs installed to weatherproof the connector
New cable with contacts crimped onto 20 awg wire.
Contacts inserted into connector. 20 AWG insulation diameter ensures that there is a 100% weatherproof seal when the contact is seated inside the connector
Locking the contacts
Tie wraping the 6 CB contact pairs and dongle cable so RD0_2 can be reinstalled into the radio
Now reconnect the two connector to the Radio. RD0_2 first and then RD0_1.
This Mod will totally disable the hardwired BRP headsets but will give you the XM Radio as well as all other radio functions via Bluetooth.
This is the same cable I used to install the dongle on my 2014 RT but I had to 16 more sealing plugs ($1.60) and A OEM Connector ($6.00)
