How tight should the oil drain plug be?
Most, including dealerships, get these plugs way too tight. They only need to be mildly snugged. I like to use a stubby 3/8" ratchet and even then, not put a lot of pressure on the plug.
I've never seen a plug fall out or even leak. But I've seen many that were stripped from over tightening.
:agree: ...forget the Torque wrench ..... snug the socket wrench then a light tap to finish ....if it leaks so what, just tap it again .....JMHO .... Mike :thumbup:
