how much clarance is under a 2011 can-am spyder rt
electricman
can any one tell me i would like to do my own oil change i was going to make a ramp to work on it //// note my cam-am is not at home it is in the shop thay are servicing the clutch slave cy
I lift mine up with a motorcycle jack and put 8" wooden blocks under the tires. This is a nice working height to get a drain pan under and not be to cramped taking out the drain plugs.
Room
My jack stands at the lowest setting is 12". Gives me room for the drain pan, and room to remove the drain plugs! Depending on your drain pan, I like 6" above it to work.
Well....
There is enough clearance to do an oil change. I do my oil changes on the ground but you do have to get down low...a full table lift would ge nice ;) but I do have other lifts for other work that can be used if you prefer to raise the spyder for the oil change....:thumbup:
