. Nobody knows - if someone says they do - well, they are guessing. This question has no usable trustworthy answer.....................JMHO.......Mike :thumbup:Does anybody Know how many miles you can ride your RT when the gas light comes on? Just curious, and good info to know.
Based on a few fill ups with the light on for a bit, that may be a safe, close estimate. Going over 65 will maybe lower that number and low traffic around town will raise it, but that is about all I would push it.
The most accurate answer to your question is: "It depends." My low level light comes on when I have a between 1 1/2 and 2 gallons left in the tank. I've gotten as little as 24 MPG and as much as 38 MPG, depending on riding conditions - 80 MPH or 35 MPH - flat straight roads, or twisties in the mountains.Does anybody Know how many miles you can ride your RT when the gas light comes on? Just curious, and good info to know.
BRP states the actual ....VOLUME ...( mathematical measurement ) of the gas tank ..... However, that amount of liquid CANNOT BE Put in the tank , by design......So just use some common sense, I also carry enough GAS to go 15 +/- miles if I need to ...... I have never needed it but I have saved some other folks a long walk :yes::yes::yes::yes::yes:...... Mike :thumbup:When my light came on I was pulling into a gas station...It held over 6 gallons....My understanding is the tank holds 7.1 total.... So I figure it had about a gallon or less left, which means to me I have somewhere around 25 to 30 miles and I am walking....Assuming the fuel pump will suck the tank dry and it holds what the factory says it will.....
