I dunno about the specific '
3.625" ID rubber Fernco cap' that you've got, it sounds to be a bit bigger than those recommended/usually used?? Maybe it's the next size up?? Or possibly it's cos it's '
rubber' and not the Rigid PVC cap that I believe is the one most commonly recommended & used for this purpose here in Oz?? :dontknow:
But for all of these '
protectors' that I've seen here in Oz (all 3 & a tiny bit" ID Rigid PVC plumbing caps
) once the airbag is sitting in and bolted/secured into the upturned cap and the bag's inflated to anything more than about 5 psi, it pretty much fills the cap and there's
very little likelihood of any stones or even fine grit getting in there! :shocked: It's a pretty tight fit once there's air in the bag, and when the pressure gets higher &/or load settles onto the air bag, it fills the cap even more tightly & stops
ANYTHING from getting in, even water.... and I've seen some air bags with protective caps that've been in use for well over 100,000 kms without anything getting caught in the cap - not even dust! :shocked:
Mind you, I do a fair bit of gravel & dirt road riding, and I personally
DON'T have one of these extra 'protective caps' fitted to my RT's air bag, nor do I have a belt guard for that matter, and I've never had any issues. There again, I might not wash & polish the brightwork & tupperware on my Spyder after every little ride (cos it gets washed whenever I ride in the rain anyway
) but I do generally check, inspect, and clean/blow out all the little nooks & crannies as well as the works & fittings underneath at least once every week that it's been ridden; including jacking the Spyder up & blowing out any dust &/or gravel etc that may've collected under the (naked) air bag, so there's not much chance for anything to be in there long enough to cause a problem... But still, wherever
I can, I tend to use '
Preventative Maintenance' rather than relying on bolt-on bits or a/mkt added protection, and I'm gonna be down there checking the tire & belt & sprockets & bearings etc anyway, making sure that everything's in good nick & doing what it should be as it should be in preparation for my next outing, so there's no '
extra effort' involved & I
KNOW that it's all rarin' to go at the drop of the flag. :thumbup:
Over to you... :cheers:
