How difficult is Removing the BRP Back rest on 2013 ST-S?
Phazernut
Recently bought this 2013 STS. How difficult is it to remove the back rest? The bike will be ridden solo and I have the stock cover to go back on the tail. No need for the back rest.
From that pic, I think you will need a re-placement tail cover... It should be easy to remove. Mike :thumbup:
Well, there's a couple of options: you say stock cover so that would involve removing the sports rack - that's just 4 bolts & a release cable for the main body. The stock tail cone can then cover the aluminum bracket, unless you want to go ahead remove that too, an additional bolt & nut that're a lil harder to reach going through the frame under the seat.
Here’s an installation that gives the idea:
https://youtu.be/sqmMhaUtg9E?si=VfQL3iZfmIKfNGx3
I do suggest hanging onto the Sports Rack, as they are now discontinued & harder come by!
