How can I make a 900 more Rally-like?
greer
I'm just starting to learn about the Ryker, but fairly certain I'll be making a purchase. Thought at first I was stuck on a Rally, but now I'm not so sure. I don't intend any off-road riding, but I'm guaranteed to ride some gravel. I've been reading about modifications to these bikes - taller shocks, a skid plate, suitable tires, anything else I'd need to make a 900 gravel-ready? What am I overlooking? I think it'll have to be a '22 for the factory cruise control. I understand some folks have added aftermarket cruise, but that's way over my head. I appreciate any thoughts, opinions, experiences you all might share. Thanks!
Sarah
6,000 mile report, May 7 to Oct 22, 2020 (5 1/2 months)
Positive
1. The Ryker is a lot of fun, whether instant acceleration from any speed or aggressive cornering.
2. Many design aspects are very practical, from exhaust layout to a bit of storage in the glovebox.
3. The driveshaft/swingarm design is streamlined and very smooth, as a Moto Guzzi V7II
4. Solo seat is actually comfortable, especially compared to stock seat on 2012 Triump Bonneville or 2003 Sportster XLH 883.
5. Engine oil and transmission is easy to drain, if on ramps. Refilling easy, with proper funnel.
6. Cooling system very efficient, even in ambient over 110F.
7. Amazing price point ($9,999 for base 900)
8. Excellent turning radius and at a higher speed than a M/C at same radius
Concerns
A. Changing CVT belt every year for a 1,000 mile per month rider makes maintenance costs a bit high. $220 for belt is OK, but if not DIY, then expensive labor. No provision to monitor belt life / width without removing cover.
B. The Rotax 3 cylinder 900 motor delivers HP well, but cruising at 6,000 to 7,000 RPMs will likely affect life expectancy.
C. Can-Am recommended service interval of 6,000 miles is extremely optimistic and most likely marketing driven. First service at 1,000 miles and every 5,000 miles, thereafter, with pure synthetic oil would likely prolong engine life.
D. No parking / emergency brake. Transmission only equipped with cable operated parking pawl.
E. Large axle nuts may impede roadside assistance for tire repair/replacement.
Negative
a. 33 MPG (likely due to high RPMs) for a 611 pound machine does not provide a long range for a 5.28 gallon fuel tank.
b. Probably due to higher RPMs, ear plugs are essential for rides above ~35 MPH.
c. Stock front shocks do not control the front tires as should be expected. Replacing with 400 mm shocks, with full length springs, is a huge improvement and an extra 2" of ground clearance (base 900). Thank you Chris56 and Tslepebull.
d. The mounting angle of the rear shock provides very harsh reaction on a rough road. The Rally model has a better mono shock, but same angle.
e. Draining the final drive is a bit messy, but refilling through the disc brake slot is not an issue with tube from 75W90 bottle.
f. Changing the oil filter is messy, especially cleaning out old oil. Any oil that spills is difficult to wash away and may drip from the bottom pan for a few days, even after attempting to clean in a coin-op car wash.
g. Starting sequence is annoying: Key popped on, stop run on, press start button, roll throttle forward, press start button AGAIN, while foot on brake.
h. Parking lever rattle annoying.
i. Fuel pump whine slightly annoying, but probably not life expectancy issue.
The Ryker is not an "Off Road" vehicle. It is an "Off Pavement" vehicle. Big difference. No matter what you do, you're going to find the rear wheel lacks the traction needed for real off road riding. And the 3 wheel stance does not lend itself enough articulation or ground clearance to get over much of a hump. You could jack it up and improve on this aspect. But you're going to drastically change its on-road characterizes for the worse without really gaining all that much.
The Rally comes out of the box with enough ability for most reasonable gravel and even dirt roads. I think I'd get one and start out with mild expectations (and modest off pavement trips). Then try more challenging escapades a little at a time and adjust as needed. You might be surprised that you really don't need all that much to do what you want.
If you want to do real off-roading. Get an adventure bike or off road quad.
Coming back from Bryce Canyon along highway 12, I stopped for lunch in a parking lot with deep gravel.
To climb the incline back to the highway, I had to approach at a angle to get traction.
That was my only traction issue.
It did fine on several miles of rough road on my 6 day 1115 mile NV-AZ-UT trip and no issues off paved roads any other time.
As much fun as I found the Ryker to be, my decision to sell was due to:
1. High RPM cruising
2. 33 MPG average
3. 10K mile belt replacement
...but it was comfortable for 460 mile days (Extraterrestrial Highway)
Further on Auxito LEDs
I used on last Triumph, XVS950, XT250 and Nissan Frontier.
For the XT250, I should have ordered the one with metal tabs, as the one I ordered is plastic (thicker) and required minor holder mods.
Longer springs and better headlights are a must.
I don't think you'll get that "rally mode" option available that defeats all the safety features though. Not much can be done there as far as I know.
Thanks everybody. I'm not a slowpoke, but I'm not a hooligan either, so I don't know if I'd ever be one to take advantage of Sport and Rally mode. Honestly, the simpler the machine the better as far as I'm concerned. I'll keep reading and studying and keep in mind the cost of cruise, shocks, and Max Mount for the Standard 900. But I'll need a full rear fender for the Rally, so that's at least $100 plus the hassle. Markubis, do you mind telling us what front shocks you're using?
Sarah
Edit. I just caught on, folks recommend longer front shocks for the Rally, too.
Options for 400 mm shocks as posted above and from the Tire sticky at the top
https://www.amazon.com/GZYF-Motorcycle-Absorbers-Universal-Kawasaki/dp/B00XVH4NVG?th=1
I think these are the 400 mm RFY shocks mentioned by chris56 in the tire sticky
https://www.amazon.com/Wotefusi-Abs...+motorcycle+shocks&qid=1643653857&sr=8-4&th=1
Sarah
Those 400mm RFY shocks on Amazon are what I use. It's like night and day compared to my original Rally front shocks.
I did have to pop out out the inner sleeve on the bushings to fit the Ryker bolt diameter. The shock set comes with multiple sleeve sizes.
Thank you, Markubis!
So, I'll be looking for any of the '22 900 cc bikes, and add factory cruise to the standard. Nice to have more options.
Sarah
Cruise, Maxmount and full fender come on the Sport model.
Also only has the Eco and Sport modes, no Rally mode.
If you are going to change the shocks and springs, why spend more money for a Rally.
The standard 900 has a full fender, which can support a small bag, secured with lashing straps and footman loops.
Also a gallon of extra fuel for the Extraterrestrial Highway ride.
Cruise would have been a plus on my 2020, but the ECU did not support it, at that time.
It is easy enough to smoke the rear tire in normal mode and for 2020, I actually preferred the standard wheels.
https://www.spyderlovers.com/forums...sions&p=1520573&highlight=footman#post1520573
Both standard and rally benefit from 400 mm shocks.
If you decide you really need different shocks and springs.
Can-Am has Fox shocks front and rear for the Ryker.
This would not void the warranty on a new bike.
Fox makes some good stuff, and is found on some high end BRP sleds and side by sides.
Just a thought.
Interesting stuff.... :helpsmilie:
But AFAIK/Can see from all that lot^^ you juuust might be better off simply to buy a Rally in the first place, then mod IT to suit your specific needs/wants/desires :popcorn:
Looking at the list of things to do/get, that'll probably be cheaper too! :roflblack:
Thanks so much, everybody. We're headed out to look at a lightly used Sport today. I'll keep you posted :)
Sarah
