? Hose fitting on top of fuel pump cap
cueman
Is there a hose fitting with nothing connected to it on top of the fuel pump cap? This looks like a 90 degree white plastic fitting that a hose would slide onto. Is it supposed to be like that? :dontknow::dontknow:
I can't absolutely answer your question, but it looks like it in this blow up view. I'm looking under part #10b on top of the fuel pump & the short tube pointing at 10:o:clock. Straight to right of end of part #50. Maybe I just confused both of now!
https://www.cheapcycleparts.com/oemparts/a/cam/5c75b23387a8661978f470a8/fuel-system
Yes, l believe it is correct to have no line on the fitting on the right side. I just saw a pic of the gas tank area with the body pivoted up and there wasn’t any hose on it. I was worried for nothing. :ohyea: cueman
I believe it is a filler overflow hose. i filled up to the top, and while there was not over spill on the bike, the was a minute fuel wet spot under the bike ...
