hook up heating gear
Direct to the battery or the customer accessory circuit is under the rear seat. Not sure what that circuit is rated for, preferred would be battery.
Hook up
There are two customer accessory hookups on the F3T; I imagine there are with the F3S. Not positive, but remove back seat, see if there is a rubber boot on the end of a wire. Under the left panel where the safety card is, is another. Hook to either. Both are switched power. Only work if bike is on, and running. Joe
Most all recommend direct to the battery. I would only hook it direct to battery. Only time I did not I had a jacket fire on the freeway. They need full power going through the fuse to work properly. I have owned three and have used them on half a dozen bikes.
Jack
