hschuchman
I am adding a RAM base mount to the center area of my RT handlebar. In order for me to do this I will need to remove only one of the four hex bolts and then use the new bolt for the RAM mount to replace it. I have attempted to take off the bottom left bolt but the bolt is screwed in so tight that my ratchet would click, due to it was more pressure then it can handle, and then eventually the hex bolt became stripped in the center. I tempted this with the other three bolts, but they are also too tight, they are not stripped. I also used WD-40...no luck. Any suggestions??
