Hevy wheelchair loaded on the RS, is it possibly to maka an on/off switch forthe PRS?
Henning
The pillion rider switch (PRS) activated when 18 kg is detected on the passanger seat. But the wheelchair is not touching the seat at all and it wheight more 18 kg because it is electric driven. So how can I make the prs active then?
why?
how heavy is the chair? do you want the bike to know it has extra load on it ? i'm confused. but that's normal:roflblack:
Let's see..!!
Don'have diagram handy but if it is an on off pressure switch you could tap in a manual switch. This way you could switch it on when the chair is present off when not and it would still work normal when ryding with a passenger....:thumbup:
The easy way....Take the switch out of the seat via the 2 torx bolts and wrap it about 5-6 times with electrical tape while holding it depressed. Reinstall.
Sent from my SCH-I545 using Tapatalk
