Hesitation on start?
DragonReborn
I have around 10 years experience riding standard motorcycles, and 10 years before that racing three and four-wheelers, so adjusting to the Spyder hasn't been too difficult. I'm thinking about buying either an RT or an ST. My passengers would of course prefer I get the RT. I'd have no problem with that, except both 2013 RTs I tested have an issue that bugs me.
I'm not much of a mechanic, so I'll explain it as best I can! When I go from a complete stop and give the RTs too much throttle, it hesitates for a second or two before it 'catches' and speeds ahead. The workaround is more gradual throttle, which I'm sure I could adjust to. My fear, though, is being in a situation where I need to gun it and it not responding. The ST's I test rode did not have that issue and were very responsive! Both RTs I rode had been sitting out in the cold and the STs were inside, if that makes any difference, I know my bike doesn't like the cold too much.
So my question to everyone, is this a common issue? Something I should be overly concerned about?
Thanks,
Clint
Try grabbing the ":loud grip" after the bikes are fully warmed-up; there'll be no hesitation. :thumbup:
And... :welcome:
I would say it is not normal. You did not say if they were SE (Semi Auto) or SM (Manual) shift. The SE will take a little build of RPMs before the clutch fully engages. You may want to try a 2014 RT it has an improved drive train.
Here's the thing..!!
the pre 14's have a centrifical clutch system requiring 3,500 rpm's to fully engage. When at operating temp they are very responsive but you do have to keep them up over 4,000 rpms. The new 1330 triple with the 6 speed tranny has a hydraulic clutch which is much more responsive...:thumbup:
The nanny also does not allow 'jack rabbit' starts. The throttle is throttle by wire. The grip controls a signal to the computer and the computer tells the engine how much air & fuel to inject and monitors engine rpm. Engine acceleration is therefore restricted. Here's a quote from the 2013 Owners Manual
NOTE: This vehicle is equipped with
an ETC (Electronic Throttle Control).
The throttle plates in the throttle body
are controlled electronically and can be
opened or closed irrespective of the
throttle twist grip position when necessary.
It may happen that when you
accelerate, the VSS (Vehicle Stability
System) prevents engine acceleration
in order to maintain vehicle stability.
Then, when the vehicle is stabilized,
the engine RPM would increase as requested
if the throttle was maintained.
This would be felt as a "delayed" acceleration
Interesting. At least I wasn't imagining it! Thanks for the explanations, that helps. Now I just need to find a decently priced 2014 RT. It was a lot easier finding the 2013s, now I know why!
Let's see, every vehicle I've owned in the last 22 years added together equals around 10k...and this is looking to be 20K+. And yet I'm still intending on getting one!
One place where you can really feel the hesitation is to be stopped at a traffic light, light changes, you gun it hard doing a hard left turn. If the turn is sharp enough you'll feel nanny hold back and then you'll feel the release after you get straightened out.
Yeah, that sounds about right. Where I felt it most was turning out from the dealership. It wasn't the friendliest of intersections, so having it hesitate with cars coming panicked me a little!
