HELP
Jfhaas
Can anyone tell me were the oil filter is on a 2015 RT SE6 is. I watche the video and he shows it on the right side. Striped the right side and nothing is there. Before I talk of left side I'm looking for help..it has a 1330 engine. Please help. Jack
It's on the right side. Did you remove the acoustic panel? Look for a large 36mm hex nut plastic cap. Filter is under cap.
It is on the right side. You will need a 36 mm socket to remove the cover that holds the filter. Did you watch this video ----> https://www.youtube.com/watch?v=ZPeb1YqV4Gw&feature=youtu.be
He's pretty clear on where the oil filter is located.
Hope that helps.
Pam
