2013 RTL SE5
I was adjusting my belt tension an alignment. Test road for a very short distance, belt was still to far from the rear sprocket flange. blocked the front tires again, loosened the axel bolt, jacked the rear tire about 1" off the ground stared the bike let the wheel spin in first gear, made my adjustment. turned the bike off re-torqued the axial bolt. started the bike, PARKING BRAKE WILL NOT RELEASE, CHECK ENGINE IS FLASHING, LIMP MODE CAME ON.
I pulled the codes: C0031 ( left front wheel speed sensor failure ) C0034 (right front wheel speed sensor failure) C006C (vss rate message error). I expected the speed sensor errors as the front wheels were stationary while I was making the adjustments. and should clear after a short drive. The parking brake failure to release is a mystery. I know that I can loosen the cable at the rear brake so the bike will move, but is there anything I can do to get the brake to release with the switch as it should.
Any suggestions and or help will be greatly appreciated.
Thanks, Roger
THANKS TO THOSE WHO RESPONDED. WITH IT RUNNING AND HOLDING THE BRAKE PEDDLE DOWN, I was able to get the parking brake to release, drove maybe 600' and the codes reset. All is good now!!!!!!
Thanks, Roger
