Help with seat removal
wyliec
The electrical plug under the seat- I tried to disconnect last night; but, didn't want to force it. It looks like you press on a tab and pull. Is this the way it's done? I just didn't want to force it and break something.
Spydergirl,
If you read this, I just received the roadkrome piece that goes under the seat. The instructions say to remove the seat. I went back to your instructions and you say to just lift the seat. I don't want to remove anything I don't have to; so, I'm wondering if I really have to remove the seat. I'm just trying to get everything in order before I start.
There are 2 bolts that hold the rear seat sensor,, It would be best to just remove the 2 bolts and keep the electric plug connected, but yes you are correct you should be pushing on a TAB that will release from the Female end and then you can remove the seat with the sensor still in-tact.. It makes no differance how you do it but them are the two methods that I know of...
Joe
(X)
