Oldpepsiguy
Hi I bought the Sequential Fender LED's from Value Accessories. Took all the tupperwear off that is necessary. This is supposed to be plug and play except on my 2019 Spyder RLT which has a single wire that you T-tap connect to your mirror harness positive wire. I did all that and these lights will not blink, they come on as running lights. Also I plugged the mirror back into the harness and it blinks as usual, nothing but a steady glow from the leds on the fender. I'm glad I haven't drilled holes in my bike yet, thought I should mock up the wiring to see if it works first. Nope, I still have the bike torn down, thinking I may just send these LEDS back and forget it. I changed out the harnesses for lights with the one for the other side, no change. With a volt meter I get fluctuating voltage when signal is activated as it should to blink but no blink on the LEDS. Help please. Thanks in advance, Jim.
ray:
