About the only thing that really
IS critical is that your 'diversion hose'
MUST go
UP from the tank and stay up higher than the top of the tank for long enough to stop fuel from sloshing &/or running into it as you ride the Spyder!! The gas in your tank
will slosh around under the forces of ryding, as you accelerate, turn, and brake; and it WILL be able to be forced into that hose, so your hose must go UP above the tank/fluid level and stay up for some distance or you'll collect raw fuel in the hose thru that sloshing & it will eventually get forced out the far end by the fumes evaporating off the gas in the tank. :lecturef_smilie:
And even tho you've done a cannisterectomy, because of the above it's still a good idea to avoid over-filling the tank!! The fuel in the tank will
almost always be a lower temperature than ambient air temp when you fill your gas tank at the bowser, so once the gas gets into the tank, it
WILL start expanding, even if just a little, as its temperature increases to ambient! And then it'll expand even more as you ryde & the engine starts bringing everything up to
ITS operating temp in turn; altho you will be using some fuel then... altho you might
like to think you're using fuel faster than it's expanding (unless you're ryding gently & slowly in warm/hot conditions) - but then again, you might be very surprised at how much fuel
actually does expand as its temperature increases, especially if the ambient & engine temps are warm enough for ryding, but the fuel temp was pretty cold when it came outta the bowser.... saaaayy, as cold as it'd be coming up from an underground tank that's buried in 'winter temperature' soil & concrete etc!!
So don't fill your tank to the absolute over-flowing limit and make sure your cannisterectomy line goes
UP & over the top of the tank level, stays that high for some distance, & heads to the
REAR of the machine so that it can vent fairly well clear of obstruction or heat sources - & btw, if you're concerned about the risk of being close to the muffler/exhaust end, even just putting it on the side away from the muffler is generally far enough away from any of that to be fine; but in any event, it's
WAAAYYY better being vented back there than it is being vented up front where
ANY FORWARD MOTION (ie, you ryding!! :shocked
means that your hose WILL be venting flammable gasses over a larger, hotter heat source that
also has the potential for creating the odd spark or two!! :yikes:
Good Luck! :cheers:
