Help Needed
PW2013STL
UPDATE
After a lot of searching I ordered a new mirror assembly from a dealer. Should have it Tuesday. Wish me luck on not breaking this one :shocked:
Does anyone have or know someone who may have an RT right mirror glass? Or if you know of a salvage yard that may have one. I broke mine attemting to remove it for adding LED turn lights behind it. BRP will not sell the mirror glass only and you have to purchase the complete housing at $194:gaah:. I tried a mirror company as well as an auto body shop and neither could help with a mirror that light can shine through. So I am hoping that there maybe a damaged housing that has intact glass
Have you tried cranking-up your internet searches for motorcycle salvage yards? :dontknow:
Good luck and Happy Hunting! :thumbup:
Tough one..!!
have seen this request before. One is to find a similar repacement mirror at a car acc shop large enough to take to a cutter and trim to fit..Will be a lot cheaper than an oem mirror assembly...:thumbup:
Some window glass repair businesses have and will cut automotive mirror glass. Please note mirror glass is different then regular. Make some more phone calls.
I have to ask. You have a ST why are you looking for a RT mirror?
Traded the ST in for a 2014 RT-L. What pictures I have are in to large a format for changing my sig picture. I need to reset my camara and clean the :f_spider: again to get the proper picture.
Do you have MS Paint on your computer?
You just need to downsize the pictures, to about 200 or so pixels in width... :thumbup:
Issue I am finding is most mirror glass is coated on the back side and light will not shine through. Not sure if the mirror used in accessory mirrors has that type and I do not want to pay to find out it doesn't:gaah:
Does anyone have or know someone who may have an RT right mirror glass? Or if you know of a salvage yard that may one ihave one. I broke mine attemting to remove it for adding LED turn lights behind it. BRP will not sell the mirror glass only and you have to purchase the complete housing at $194:gaah:. I tried a mirror company as well as an auto body shop and neither could help with a mirror that light can shine through. So I am hoping that there maybe a damaged housing that has intact glass
I broke the same side installing the same led turn signal I give up looking and had a glass company cut me a reguler mirror for my right side I saw some replacement mirrors at auto zone I don't know if it will work and they have to be cut
Good Luck! :thumbup:
