Helmet locks. Really?
Denny B.
I find that if I try to use the helmet locks under the seat ('14RT) that the seat won't lock down. Is it just me?
Hi Guyver!
Here's one that I just KNOW you can do something about! :thumbup:
What we need, is a loop of cable that can be run through the helmet's D-rings, and hooked over the "locks".
If it was long enough to allow the helmet to rest on either the rider or passenger floorboards... :2thumbs:
Have you tried the frunk?
My wife and I have the ST-1 Hybrids, and the two of them fit nicely in the frunk...even with the removable jaw pieces connected. Just a thought.
As I see it..!!
you need some adapters or extensions for them to work...I think it was an afterthought but good pitch having helmet locks...:gaah:
Might be the strap length
I think it depends on the helmet strap. I could use the helmet lock with my half helmet, or my wife's full-face helmet. Yet, could not with my full-face helmet. It was this way for both the 2012 and 2014 RT. I have to admit I had not measured the straps to see what the difference in length is. Also, for the helmets that fit with the locks I noticed it did not matter what side I uses.
Hi Guyver!
Sorry, but that won't work. If the helmet is not tight against the saddle, you can raise it up enough to get enough slack to un-loop the loop from the helmet lock under the saddle. I tried what you suggested a few years ago & thought I had a slick answer to the problem. It failed the Can-I-get-the-helmet-without-unlatching-the-seat-test.
:gaah: Thanks for trying! :thumbup:
:D But...
What if the loop was cut out of a piece of metal, and JUST large enough to fit down onto those hooks?
Would that help? :pray:
WELLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
:D But...
:agree::yes::yes::yes:..........For you Bob ....I'm on it............I have also been frustrated those useless things .......:thumbup::thumbup::thumbup:....Mikeguyver:2excited:
Even my old 1976 Honda 750 Super Sport had 2 very functional helmet hooks under the locking seat. This was on a bike that if I remember correctly cost $1,00.00 new. You would think that on a $30K machine they could have figured something out that would work when all the storage compartments are full. :lecturef_smilie::gaah:
Helmet Guardian for us too!
We have used the Helmet Guardian locks on both of our Spyder RT Limited's. :thumbup: The BRP design has a lot to be desired! nojoke We have Nolan helmets and utilize the helmet "T" extension when using the Helmet Guardian locks. Just need to be a little careful when hanging the helmet on the exhaust side so it doesn't touch the exhaust!
Here's a couple of pics:
