Heated Seats and handgrips Not working -any fix ideas?
Hokiev
My 2015 RTS heated Seat, Passenger and Driver Handgrips stopped working. (for those not familiar with this model the Seat works off the Passenger Heated Hand Grips)
I checked both fuse boxes and don't see anything labeled specifically for them (trying to avoid pulling ALL the fuses). Does any one know which fuse to check or if there is another item that might be on the same fuse I can verify if that item is working or not?
Any other ideas if the fuse is good?
I checked the plug under the seat to be sure they all were plugged in, which they were. Not sure where else to check.
In the Right fuse box check: Fuse J2, Fuse F5 and relay R4. If Fuse J2 is bad the radio and horn will also not be working. If the radio works and the horn doesn't check fuse F5 If the radio, and horn work and the heated grips don't then check relay R4
attachment.php
attachment.php
Thanks, I will try that Friday afternoon.
