AsphaltEagle
PO removed the passenger heated grips and replaced with non heated arm rests. Since the f3 limited 2018 does not have a 12 recp. in top case i wanted to use this power for that. I found two plugs under pass. seat , they must be for grips. With engine running and gripheater sw depressed the right side one has 12 v but the left side nothing.
WHY would this be? Also the wirewires look a little light for using anything with a heavy current draw.
