HEAT PROBLEMS...?
SPYD3R
HEAT PROBLEMS...?
WHAT HEAT PROBLEMS.....? :hun:
you just don't have the correct AIR FLOW around your motor...
check it out, my latest DIY project for my '09 RS SPYD3R....
brings down my temp by 1 complete bar... :clap:
heat
I had an 08 until this past May. Dropped the heat by that much by having the Spyder re-programed to the specs of a 2012 RS.
Sweet . . . the Vertika scoops look good, to, but so darn expensive.
EXPENSIVE...?????????? :ohyea: NOT :lecturef_smilie:
these r DIY scoops.... 1/16" aluminum sheet cost me $3.00 at the scrap yard and $3.97 for RUSTOLEUM 'hammered' paint @ Walmarts... and about 2 hrs. labor....
it was fun... and CHEAP... :yes:
Nicely done..!!
they should work for a lot of years RS/RSS. Looks great on and if one gets the template quite easy..congrats..!! :2thumbs:
That looks as if it was BRP-designed to be there!!
Dan, nice job, but I know you decided to do it after seeing my Spyder and hearing how much the scoops cost!:clap:
I realize these are home made and cheap and "sweet" was the part of my comment concerning them . . . the expensive comment had to do with the Veritika scoops. I have a 2013 RT which is a different design. so your scoop might not fit . . . nor have I the expertise to do what you did.
Nice. :thumbup:
If demand was high enough these could be injection molded.
Edit: They could also be stamped using a softer moldable plastic.
Something similar would work well on RT's too. Especially those with the new adjustable wings.
Great job, now is time for you to make some money, sell them.....:clap:
sorry B'Ball, but i'm not into making $$$... i'm retired and just enjoy 'make'n DIY things', and i only make things like this for myself and maybe a few frenz....
check out my other post for FOOT PEGS, FOOT BOARDS, LUGGAGE RACK, MUFFLERS, etc etc etc... however, i'll be happy 2 help u in anyway 2 make u'r own....
heat scoops
Very nice. :clap: If you could post a scale drawing for the template then I am sure many of us would attempt to make a set also. I can copy well but not much good on originality.
MMcc... here ya go...
now don't forget to add TABS as seen in the 1st of my post....
good luck, and enjoy yourself while making your set... ;) :popcorn:
