Heat Issue RTS SE5 2010
JRWW
I have a Autocom Superpro unit installed under my seat and it gets extremely hot. I was listening to my Ipod through my helmet speakers and after 2 hours riding the sound started to distort as if there was way too much base. Just wondering if anybody had experienced a similar problem. The main frame stay under the seat was almost too hot to touch and I'm concerned that the heat may damage the Autocom unit.
I'm not sure where yours is located. I have had similar Starcom1 units in the nook under the glovebox (actually beneath the frame) and beside the frame in the rear, near the positive battery jumper. I did have occasional problems with the one near the glovebox...possibly heat related, and I definitely had periodic interference issues with the proximity of the wiring running to the Starcom1 to the ignition wires. I have had no issues with the one in the rear, and I'm not sure how hot it gets. I'd look at your mounting position. If the Autocom is mounted to the frame, you may want to try it elsewhere. In general, the heat under the seat is probably acceptable, but location, the quirks of individual units, and local weather conditions may be a source of difficulty.
