PW2013STL
Decided yesterday to repack my trailer bearings. I did that last year about this same time. Last year the bearings and races looked like new so did the repack. This year expecting the same, but found that three of the four bearings had wear on the rollers and all four races showed wear. Both rears had the most wear. I guess the Alaska trip with the great roads we encountered had an adverse effect on them. :banghead:
I pulled all the races and ordered a set of bearings and races through Amazon from here for under $27.00 including shipping. Grease seals may not fit, but I already have a set of those
Westernprime Trailer Hub Wheel Bearing Kits L44649 L44610 Spindle 1.063'' (1 1/16-Inch) Grease Seal 15192TB I.D. 1.500'' for 2000# EZ Lube Axles
If you have not looked at your trailer bearings you may want to check them to avoid on the road unpleasant surprises.
Once installed I will be ready for Spyderfeust!:yes::yes::yes:
