Headlights Stopped working!! Any fix ideas/suggestions?
erinfire703
I don’t ride a lot at night so I do not know when this actually started. Both front headlights and mirror running lights are not working. There is also no actuator noise when toggling the HI/LO switch. I have checked the fuses and relays in the frunk and under the seat. Voltage shows 14v at idle. Not sure where to dig in next.:banghead: Only electrical mod I have done is adding the LED strips to the fenders and replacing the fender running light bulbs with the appropriate LED bulbs.
Thanks in advance!!
2011 Spyder RTS
****UPDATE*** Making progress! Swapped relays around and got the headlights to work.
Bad Relay ? ?
Thanks in advance!!
2011 Spyder RTS
What was your final fix?
A bad relay(s)?
Corrosion on the contacts?
Or something else?
Thanks for the Heads Up. ......:thumbup:
