Has anyone added Marvel Mystery Oil - any comments?
I remember adding a couple ounces of Seafoam to one of my past two wheelers oil. I then took it for its warm up ride and dumped it out. It's supposed to help loosen up the crud. That said, I wouldn't add it to my Spyder's synthetic oil. No real need to do so...
I used to mix a little Marvel Mystery Oil into the Alcohol for the Cart Racing engines. The pure Methanol would strip away any lubrication left on the cylinder walls or valve stems. Don't race them any more, and don't have the exact mix written down anywhere. It was a mix of Methanol, Tolene, and Marvel Mystery oil. The oil was just ounces mixed with the fuel to provide some residual lubrication. Not sure how much it helped, but never had an engine seize up on 30 lap dirt track races.
Has anyone added some marvel mystery oil into
their oil and just how much?
What are your comments?
If you search on 'Mystery Oil' (as bolded there <, including the ' - ' bits ) without ticking the 'Search titles only' box and do some reading, there has been some discussion on this in the past, some going a fair way back too. (y)
