Harbor Freight 1.5 ton Jack on Sale for $69.95
ulflyer
I have one like it and its low enuf to slide under the front. Nice jack and works smoothly. Regularly $119. Aluminum frame.
Sorry but I had 3 of these fail in less than a year. Cheap Chinese junk and a jack is no where to cut corners. You can get decent built aluminum jacks with steel valve bodies and proper bracing to safely hold the load. I got an ANSI rated one from Northern tool for less than $200 and its been a world of difference. Had it several years now.
Have one..!!
works well but only use it to lift then brace with jack stands. Hard to lower slowly but can't beat the price. Also have the atv from sears works better for $20.00 more when on sale...:thumbup:
Saving money on a lift seems great; but they never fail without something on top of them...:shocked:
Sometimes, it's just best to buy from the "top shelf"... :thumbup:
I have been using the hell out of my "cheap Chinese junk" jack quite a bit. It's been flawless for me....
The key to get it to lower slowly is to step FULLY down on the peddle in one shot. If you let up it comes down fast.
http://www.harborfreight.com/rapid-pump-15-ton-compact-aluminum-racing-jack-68053-html-7814.html
If this is the one you mean- I have Used it for 6 months and changed shocks back and forth 3 times on my Spyders and it holds Great and if you Pay "Attention to" slowly turning the handle to lower it and Quickly tighten to stop lowering its Great!!! I had NO problem changing shocks with this and thats a Big test for a Jack for me!!!:clap:
Plus- Always put stands after Lifting!!nojoke
