Handlebars Quick Question
zavalza
Can someone let me know what is the diameter of the handlebars for the spyder (stock) I dont have a micrometer to measure them myself and the idea is to install a pair of clamps for the Rumble Road Ultra speakers. I have tried over the BRP site and several forums to get it but to no avail, I think they are 1 1/4 but I might be mistaken so please let me know and thanks in advance
Regards
Thanks Mark
Yes for the grips it seems that is the size but the center console it seems bigger, in one of the sides (right) I can remove a black plastic cover and expose the bar with the 7/8" but on the left one the only option is to put the clamp in top of the frame for the center console :( thanks for the reply
Thanks Lamonster
I am not good with tools yet, so maybe I am not understanding correctly the measurements, but the speakers came with a 1" clamps and they dont fit because are not big enough. So I assume they need to be bigger not smaller, is that correct, maybe I am wrong and please I am not kidding indeed I am still learning :)
Thanks for the clarification that was exactly what I was looking for :)
Now I have a side question, will a 1 1/2" do the trick for me ....
I will post my results or my disappointment here as soon as I get those clamps :)
Thanks again
Thanks again
I would say so, if you need to you can slide a piece of rubber in there to take up any slack.
I created my own u-bolt by buying a single piece of straight threaded bolt and clear vinyl tubing (wanted black but they didn't have any) at the local home-repair store. I ran the tubing over the bolt and bent it to shape with my hands. I then cut the excess off with my Dremel. Worked just fine with the RAM mount for my GPS.
David
SpyderWolf Thanks for the tip
ntxYguy2009 Do you have any pictures to share to see how it looks? :)
Another question I keep reading about this RAM mounts do you know where I can check them out? Is there a website or something?
Thanks in advance
