stillwater
I was trying to remove the upper handlebar bolt when it stepped out the head of the bolt. I needed to remove the upper bolts to install a Lamonster ram mount.
Is there some way to remove the bolts short taking it to the dealer? I am thinking an easy out may work but I no experience with easy out screw/bolt removal. The thread locker that BRP uses makes bolt removal very difficult and I am concerned it will make using an easy out unworkable.
Any advice would be helpful and appreciated.
Thanks
Hey, tried an easy out....the head of the bolt snapped off. Could this be a good thing? Can the other bolts be removed and the bars raised enough to grip the bolt to turn the broken one?
Thanks
