electricman
would not start after about 5 days or so / 2ed time .my battery tender charges at 8 amps i use it for my bike , and a 2 amp charger for the canam rt so any one know any thing sure use the help .thanks electricman
iall ready tighten them charged for 3 hour like i said 2 amp and started , my first idear was some thing was draining the battery. so i will try that its just geting to it LOL thanks for infoTighten your battery terminal leads tight. How old is your battery. Maybe take it out and load test it.
////// the book said to use 2 amp charger so my two 2 amp is not a tender i will get one and also get it checked thanksFirst off what year is your RT..?? Would help tell the age of your battery. :agree: check all your ground and terminal connections. Now you mention an 8amp and a 2amp charger. We're they connected to the battery during the 5 days..?? You should have a tender or maintainer you can hook up when not ryding but not a charger. Depending on what add ons you have and even if none RT's tend to need the tenders. You should also get the battery tested have seen them last from 3 to 7 years depending...:thumbup:
i only used the 8 amp one time in the paST 2AMP THE OTHER DAY and i was able to start it going to try starting it today < i got to see how to get the battery out in my repair man-thankstook out all the photos of battery maintainer --- 8 was to much :yikes:![]()
SARRY IT IS A 2011 CANAM SOYDER RT WITH LES THAN 6.000 MILESAND.....you still haven't told us how old your RT is.......or how old the battery is.
It is highly likely that your battery has just reached the end of it's useful life.
After you get a new battery installed, which has been fully charged first, you need to measure the battery voltage with the bike running.......to be sure your charging system is working.
A healthy battery should easily sit for a couple of weeks without any kind of charger attached.
But if you must, a fully automatic one is required.
The total capacity isn't that important because that is under worst conditions and if it really is automatic, the charging rate won't get anywhere near the max. capacity of the charger.
NOT HOME NOW I WILL CHECK THE VOLTAGE LATER ON AND POSTWhat model is your Spyder?
What year is your Spyder?
What modifications or accessories do you have?
How old is your Spyders battery?
When was the last time the battery was load tested?
What is the system voltage, at the battery, with the engine running?
Inquiring minds want to know.![]()
what the heck is the noise after turning off the spyder rt well like i whant to say about 1 hour ???:doorag: help again thanksSo it is about 6 years old now.
Might as well just start shopping for a new battery.
Age plus symptoms = about a 90% chance that it is just the battery.
what the heck is the noise after turning off the spyder rt well like i whant to say about 1 hour ???:doorag: help again thanks just to say more i was just thinking could it be the sistom turning off.:riding::riding:
if it is a high sounding noise , it is the computer , doing the system shut down ! mine usually last around 20 to 30 minutes seems like ...
Some of the earlier Spyders (like yours - & mine!) had issues with their throttle bodies allowing the engine to run on after you'd shut down.... IIRC, the fix was to extend the length of time that power was provided to hold them closed - so you get to hear that happening for maybe as long as 30+ mins after shut down. :thumbup:
