johnsimion
JohnSimion,
Bring it by and I’ll check it for free. You might have a good one from the factory. If so, great. If not, I’ll fix it. Then you ride it, and share your thoughts. Front end alignment has been a known issue since these first came out. So much so that the manual claims that uneven tire wear is normal, and alignment is not a warranty item. Yet, even with the Ryker, laser alignment is recommended. Until the Rolo laser alignment system was introduced, the factory changed the process every year, struggling to find an answer. Once it was presented to them, BRP issued memos that told dealers to buy that system. Some did, some did not. Should every dealer do them? Yes. Do they? No. But, look at your warranty, you will see it is specifically not covered!
Thank you for the offer, but for now I will pass. I hear very good things about your service, but my motto has always been, "if it ain't broke, don't fix it." Right now I feel very secure as I fly around corners and I can take my hands off the handlebar on a level road and my Spyder will track in a straight line. Unless and until that changes, I'm leaving well enough alone. If my situation changes, I will definitely contact you.
For the record, I never meant to imply that there aren't Spyders out there that need alignment. Far from it. Probably lots of them, because alignment on any vehicle can be thrown off by something as simple as hitting a pothole. It may be as some have commented, that weight of the rider(s) has something to do with the alignment. And yes, I'm sure that **some** Spyders do come misaligned from the factory. There is no factory in the world that produces a 100% perfect product. I just object to generalizing that "all" Spyders come misaligned from the factory.
I found this quote on Lamonster Garage pertaining to laser alignment: "If you own a Spyder, even a brand new Spyder there's a 99.9% chance that the alignment is not perfect. It may be within factory spec but it's not within our spec here at Lamonster Garage." I think this sums it up perfectly. My own alignment may not be perfect but it is clearly within factory spec. It's not Lamonster perfect or Squared Away perfect, but it's good enough that a noob like me doesn't know better!
You are correct that there is no warranty coverage for alignment, but the exact exclusion in the Spyder booklet says: "Tune ups and adjustments including without limitation adjustments of belt, alignment and wheel balance." Those are maintenance issues. Furthermore, according to my own research this is no different than on a car -- alignment always seems to be considered a maintenance issue. See https://www.carchex.com/research-ce...y-bumper-to-bumper-and-powertrain-warranties/. I even looked in the warranty booklet of my BMW (car) and guess what, alignment is excluded. I'm not making excuses for the manufacturers, but the situation makes sense because you could be perfectly aligned when you leave the dealer (be that BMW dealer or Spyder dealer) and hit a big pothole 50' down the road and throw off your alignment right then and there -- and I don't know any warranty that would cover that situation.
I looked in my owner's guide and don't really agree with your reading of the manual on tire wear. This is the actual text from my manual: "It is normal to see uneven wear on tires depending on how the vehicle is driven and road conditions. The front tires external or internal edges and the rear tire center tread will wear unevenly depending on if the vehicle is driven smoothly or aggressively." That sounds like pretty typical weasel words for a warranty. Also, it would be pretty easy for them to say the uneven wear was caused by improper maintenance -- and as I pointed out, alignment is considered to be a maintenance issue.
I also didn't mean to imply that the aftermarket swaybar isn't a benefit. I am 100% certain it is a better piece than stock and it may well be a benefit **for those riders sensitive enough to know the difference** or those who simply want something better than stock. If riders think it will be a benefit, I absolutely think they should upgrade. I just don't like generalizations that imply that the aftermarket swaybar is a **necessity**. It may very well be an improvement, but it's certainly not a necessity. Those of us who are relatively new to Spyders can read this stuff and think OMG, there's a big problem with my Spyder and I have to do this ... and that's simply not true. You can worry yourself sick over this stuff and 99.9% of the time it doesn't even make a difference.
