Hullo
I find I don't like looking down to see the Zumo mounted on the handlebar. Looking at the 2015 ST's dashboard I noticed four bolts: two left, two right.
I pulled the top left bolt and the hardware store sold me a longer one with a nut and lock washer.
I mounted a holder for a RAM ball (Using the nut and washer to keep it at the top of the bolt and away from the dashboard plastic) and put an extension on the ball. I've ordered an AMPS compatible RAM ball and a new cradle for the Zumo.
Here's the question:
Is the bolt I'm using for the RAM holder sufficient to carry the weight of the holder, ball, arm, another ball/mount and the cradle+Zumo? It seems to me the stress is mainly to the side at the top. The bolt is fully seated and snug.
See photos.
Your wisdom/thoughts? (I had hopes of rigging up something like Lamonster sells for the RT, the bar for RAM ball mounting. Nothing for an ST: there are no places to mount it. Thought of using the bolt I used above, plus its twin on the right, and fabbing a bar to attach to both bolts, arcing the bar above the top of the dash with one RAM attached. Not sure I have the skill so to do and the question remains: are those bolts adequate?)
See photos.
