GPS install
Mac19
i recently traded for a 2016 Spyder limited and the dealer couldn't find the factory GPS. they gave me a new one and the wiring kit. my question is which side do the wires pass down ?
If you have an RT the wiring runs down the right side. OEM setup is 1. Through the center of the handle bars 2. than to the right and 3. along the right side it will plug in to the speaker input 3.5 mm and than a two pin power plug the rest you just tie up. You will use cable ties to keep everything neat and in place.
Non OEM setup: I have seen where the wire was not run down the middle but down the side handle bars before also so that maybe an option.
:welcome: and :congrats: I see it's your first post.
Proctor MN: Right next door to Duluth. I lived in Duluth for over 20 years.
