IdahoMtnSpyder
Well-known member
I don't recall seeing this mentioned before, but if it has been then take this as a reminder.
I just discovered for certain today a bit of a seemingly odd behavior of the GPS and audio system. As we all know the GPS has highest priority in the audio hierarchy and can be heard over all other audio streams. Even when the main audio is turned off, i.e., hold the volume down button until the audio shuts off, the GPS audio still plays. That is UNLESS, the audio has been turned off before the GPS is turned on. In that case the GPS audio doesn't come through. You have to turn the audio volume on, and then when you turn it off again the GPS audio can still be heard.
I wonder if this anomaly is why once in awhile someone complains they can't hear their GPS audio.
My GPS is a tablet that is powered via a USB connection unlike the BRP unit which is powered from the radio. The audio is connected to the radio via the GPS input just like the BRP unit. Maybe the power source makes a difference but I don't know why it would.
