Can you post as pic of where the mount is on your spYder? Also, what max speed have you gone, & how long does the mount stay attached?
I haven't tethered the camera/mount (yet), but no problem to use shock cord or parachute cord from camera/mount to mirror in this location.
If you want more of what you see then the helmet is the best place...:thumbup:
Max speed in the video was 45 MPH, neither the blacktop or lime-rock grade were particularly smooth. Max speed with camera mounted on RTS, about 65 MPH. Mount has been in place for 1 ~ 2 hours at a time, I pop it off to download video to computer... Wipe suction cup and panel with wet cloth before mounting, should be good for at least 12 hours. (probably many more)
Never used a suction cup, but I think I would try to
safety wire the camera to the bike.
Hey guys, this may be alittle off topic, but, what size SD card ( 8/16/32/64 meg) do you use and how long can you record before your out of space on the card or battery runs dry:chat:. really curious as to real world numbers:thumbup:.. Thx
Granpa Pete
have had it mounted in several locations but always tethered with a lanyard to the mirror mount. Depending on the ryde I have been up to 85 mph but the scenic routes are always much slower. The flatter the surface the better the grip. Make sure it is clean and moisten the cup before installing. If you want more of what you see then the helmet is the best place...:thumbup:
