GoPro Hero Mounting on the RT Limited
GoPro mounting
been trying all sorts of different spots to mount the gopros....
-thru the windshield means schmutz & glare & reflections
-clamping to the rear hand grabs is too much vibration
-low in the air scoops is ok, but really just too low....too much road...might try that one again....
-off the saddlebags is pretty good, but I want another couple inches off the side....
-tried a hard mount to the fender---pretty cool, but fenders are prone to a bunch of vibration too
-clamped a wee c-clamp (think a small, cheap Mafer) to the base of the windscreen....good position but didn;t like the clamp....did a sticky mount there today and worked pretty well
-any arming out or extension from the mount just transmits more vibration and results in jellocam....yay rolling shutter CMOS?
-did a sticky mount just below the license plate...that was pretty cool
-used a suction cup with just a touch of arm just below the passenger 'arm rest'...that came out pretty well....
attachment.php
attachment.php
Personally, have not tried that place Patti because I suspect there will be too much vibration but give it a whirl. It might work. It seems that the further away from a very solid placement results in more vibration. The mirrors are already extended from the bike and they do bounce a little when going over bumps.
Gary
Has anyone tried mounting to the top of the side mirror?
Hi Patti!
I'd be nervous about using the mirrors... nojoke
If you hit a good enough bump in the road; would the extra mass of the camera help to unseat the mirror from it's mooring? :shocked:
I'd really hate like the Dickens; to see that happen!
I'm looking at the mounting accessories. I'm thinking either my helmet or a clamp mount to the left side of the windshield or that bit of deflector on the lower edge of the windshield. I'll play with it this winter and then decide.
I ordered and received all the parts but I have a concern. The Ram ball that mounts to the dashboard bracket has an acorn nut and a short thread. I know without a lock washer it will loosen. What did you do to make sure it stays tight?
If you can't get a washer on it, use a thread locker like BLUE loc-tite.
coming loose....
I gave the nuts a decent wank & haven't had any issues....I have Ram balls for GPS, GoPro & iPhone....
M
Ok, I have put a star washer on the ball side and blue lock tite on the threads. Will see how it stays put. Thanks
