I just finished installing JT's air filter on my RT-S. Of course, the installation itself was child's play. It was getting all the plastic that made up the stock air intake system out that was the majority of the work. Frankly, I'm a little disappointed with the BRP engineers. It IS possible to get the air intake system off without cutting and without removing the console module. :yikes:nojoke But just barely. With a little more work, BRP could have made it much, much harder. nojoke
As it is, you have to take all of the tupperware forward of the rear seat bracket off; remove the frunk; and remove the left side lateral support and almost remove the right side lateral support. The air intake system itself is amazingly huge and complex for an engine of this size, taking up virtually all of the space behind the frunk and below the console module not otherwise occupied by the engine and exhaust. It truly seems like overkill, with no apparent justification.
The good news is once the stock air intake assembly is off, working on the engine is very easy. Spark plug and wire replacement is simple and wrapping the exhaust pipes is much simpler.
I'm happy to have JT's air cleaner installed. It should result in a cooler engine bay and reduce heat transfer to the gas tank and seating area. For the time being, I'm going to leave the catalytic converter on the :spyder2:.
