Does anyone know what the total weight of the Industries 7 brackets and Givi cases is? With 350 lbs of driver and passenger and 30 lbs in trunk, that leaves about 60 lbs before you exceed load limit of 440 lbs. If the brackets and bags use up much of that, then filling the cases would likely put you over. Still not clear if 440 lb load limit includes weight of liquids (fuel, oil, water) and battery. If those must be included in the 440 lbs, then there is no way the Givi cases can work for two up. No comments about leaving wife home to avoid the load limit.
