Juuuust on the off chance, do you happen to know how long since the battery was replaced?? :dontknow: If it's the original, it's
waaaayyyy past changing; and if it was replaced just a year or two back, or even a week or two back, it
still could be finding it hard to supply useful amounts of power! :banghead:
These Spyder things are
REALLY power hungry, and if your battery
ever drops below 12 volts, your Spyder will pretty much treat it as dead.... And give you all sorts of odd codes, usually from the most power hungry modules/components (like the DPS
 ) or just throw a generic problem light (like the Check Engine Light
 ) Noticed either of those recently?? :shocked: If everything else was fine up until now; &/or it starts fine initially then not so well after you've ridden it for anything less than about 30+ minutes at Hwy speed; and
especially if you keep it on a tender between rides, then you'd hafta suspect all this as being due to a dead/dying battery! :lecturef_smilie:
So I'd suggest getting your battery load tested first, and if it doesn't drop much below 12 volts under load, then go on to cleaning & tightening all the battery terminals & earths you can find, including the one in the steering tunnel (take off the Left Wheel & go in from there
 ) cos that one is critical for the Power Steering to work properly... There's an earth for your 'Under the Seat' battery that uses a rivnut style connection into the frame, that often gets over-tightened until it breaks the threaded section free of the frame, so it might need you to add a nut underneath to get a good earth, that is a right pain to do, but it's often a cause if not the cause of poor battery performance &/or life!
And if the current battery load tests any lower than 12 volts at all or otherwise reports being less than ideal, consider it dead & look for a replacement AGM that
at least meets or betters the CCA & A/H of the original, cos right now, recently supplied Yuasa batteries seem to be a bit sub-par, while there are alternative replacements can be found with better specs and in the same or a close enough size to fit.... some Owners are even using lightweight Lithium batteries, but I'm not yet convinced they'll charge well enough on a V-Twin charging system, so they might not last too long.... :dontknow:
If it's not your battery, then it might be the DPS, and that can be expensive! :yikes:
Good Luck! :cheers:
