Gas smell is back
SllimG
I thought the new gas cap had solved my fuel odor issue. I only experienced the odor once or twice after installing the new gas cap and then it just stopped. I even did a 300 mile ride last weekend and had no gas smell. It has been odor free for well over a month. But today the temperature was up to 85 degrees and when I got home from work and parked in the garage, the odor was overwhelming. I think the warmer temperature caused more expansion in the tank so the problem is still there. I guess the only real fix is the canisterectomy. I really hate to do that and have a warranty issue later on. Sure wish BRP would give the dealers a fix for this.
you are over filling the tank wait till the pump click off and that should do it never fill to the neck
Several RT owners that have done the canisterectomy say they still have the problem....
Just had my 14k service done actually only had 13300 miles on it, but read about wrapping the header to reduce heat to the tank so my dealer did that for me and it's made a difference! Almost 80f today and minimal gas smell after stopping, in fact when I got home tonite was able to shut the garage door without having to run the box fan to cool it off first!
Sent from my home in Central Texas!
Cool weather no smell
I have noticed the smell more when the weather is hot. I don't overfill the tank and I also make sure I hear the cap click when I tighten it down. I think the fuel comes close to boiling when the weather is hot.
Gas smell with new cap
My situation is slightly different. Never noticed the gas smell with the OEM cap. Got the new one and installed it. Lots of gas odors when parked after a ride. Check Lamonts video to make sure I installed it correctly. Yup, followed the directions. Switch back to the old cap rode to town, 45 miles, stopped and filled the tank. Drove around town 74 degrees on the spyder thermometer stopped a few times. No gas smell. rode back home and parked the bike still no smell. I haven't had a chance to try again as I left for work in China 2 days later. Will repeat the test when I return the end of March. Is my bike one of the odd ones that is rejecting the transplant?
It never hurts to plany your refueling stops so that you've got at least a short trip somewhere after you fill up...
Burning off some of that new fuel helps to create room for expansion... :thumbup:
(4.75 miiles from the nozzle to the garage!)
Once that cannister gets wet with fuel it's done and needs to be replaced or removed. We get the gas smell sometimes on hot days and we don't overfill. I really think it's the nature of the beast. We always leave ours outside to cool down before putting them in the garage. It's not good for them to be rode hard and put up wet. :roflblack:
Wa BRP told my dealer
I had a thread running on the same problem. We did the canister remove,inspect and reinstall operation with the new cap. Still stunk up the garage. BRP TOLD THE DEALER THAT IF THE CANISTER WAS DRY IT WAS DOING ALL IT WAS DESIGNED TO DO,
the Service Manager asked is there any fix to which the BRP CSR said that to build a canister big enough to handle the job, it would have to be as big as the front trunk. He finished up by telling the dealer to tell the customer "when finished to park it outside for thirty minutes to cool off and ventilate then move it to the garage.
that was not a good answer IMO so I am just waiting for the right moment to make my case
I bought some exhaust wrap today and gonna give this a try. Of course I can't find it now, but I thought I read a post on here that said wrapping the exhaust was a bad idea. Any problems with wrapping just the sections of pipe that are close to the tank?
Sent from my MZ617 using Tapatalk HD
I am interested too because that is my next step in trying to stop boiling fuel in the tank which I am convinced is the real problem on the RTs.
Gas Smell Saga
I can tell you first hand that over filling is not the issue with my Spyders gas odor. I have worked with two dealers and appreciate the efforts, we have had a pinched hose, discussed lack of baffles and the fuel sloshing(?), to the canister is an engineering issue, to the liner in the frunk and not enough airflow(?) however, the tank can be full, half or a third full and the smell remains. The one factor each time that remains the same is it happens with both high outside air temp and engine temp. Well not everyone has the issue but there is enough to keep this thread and previous threads going on with this conundrum. Should Burp be visiting and read a few threads might we think it would be taken seriously and maybe fewer back room canisterectomys will be happening. Where is a spell check when needed:D
Overfilling isn't my issue either. I put the wrap on my pipes, so I'll see if that helps.
EXHAUST WRAP
To set your mind at ease ...One of our own Spyderlovers here is an exhaust shop owner and has built too many exhausts to remember....even one double pipe and muffler set-up for his RSS ( nicest welds I've ever seen on an exhaust pipe IMHO ) ....anyway He also wrapped his exhaust and told me He has NO concerns about it affecting it's longevity. In his opinion it's a very well made sturdy pipe.......Mike :thumbup:
Just the facts
'New' cap, 'New' evap canister, 'New' purge valve. 80 degress under the tuperware on todays ride and could smell fuel when stoped for any length of time at stop lights. Once home it was dripping fuel in the driveway after shut down.
Like it or not, the safest thing to do is let it cool down before garaging it.
I had my exhaust wrapped and the gas tank removed an put a heat shield on the bottom of the tank. I park in my barn but can't tell. When I ride I was smelling gas but no more gas smell when I ride now. Let me know if it helps you parking in your garage.
I agree with El Dorado Bob. It is a heat issue. I will have a better idea the next warm day we have. If the wrap works, it is a $50 fix.
After riding on several warm days (today it was 87 degrees), I can say that wrapping the pipes definitely worked for me. I haven't had any gas odors since I wrapped them. Maybe that will change when the temps rise a bit more, but for now I am pretty happy with the results.
