Firefly
Took the panels off my Spyder an got a good look around - didn't like what I found.
My gas line, along with other lines, were within 1/4" of the engine. The gas feed line obviously HAS rubbed and come into contact with the hot engine as there is visible damage - can feel an indent about 1/16" deep.
11,200 miles - so one has to wonder if this fuel line rubbing is happening on these Spyders that ignited.
None of the other hoses had damage - only the fuel feed line - which would be the main concern as far as I'm concerned.
I wrapped the various hoses with DEI heat shield and used zip-ties to hold them away from the engine. Also wrapped the upper radiator hose while I was doing this.
Easier to get to and check without the airbox in for sure. Been so long since I've had the airbox in - I can't tell you how easy or hard it would be to check your gas feed line - but I think this is an area of concern.
Here are some pics - before and after.
