Garmin Zumo 665LM
do you by chance have some pics of the install? Also I was thinking of routing the 665 and cell phone through a Sena SM10 Dual Stream Bluetooth adapter for use with the Sena SMH10 intercom on my helmet. I figured by going this route I wouldn't need to install the factory stereo (which apparently doesn't work with satellite that the RT models can have).
No need for the SM10 BT adapter if you don't have a radio. Just pair both to your headset and you're done.
Has anyone replace their 660 Zumo with a 665 Zumo 2014 RT-L. XM40 installed but looks like it is blocked out by the not installed BRP XM How do I disconnect the GPS harness from the entertainment harness?
Jack
