JayD
This is a simple and cost effective method of installing a standard Garmin Navigation unit on my Spyder RTS. I
did not want to spend the big dollars to utilize BRP unit and mounting kit.Uses standard window mount Garmin. All I had todo was pull the center plug on the handlebar and insert a bolt with a wingnut.I drilled a hole in the Garmin Mount. Works for me.
