FYI - Brake Rod Linkage bolt installed backwards blocks the Clutch Drain Plug!
Brentc
I wanted to pass along some information that might be helpful to the others who are going to do their own oil changes - When I went to do the oil change on my 2022 RT Limited, I discovered that the bolt they use from the brake pedal to the linkage, connecting rod was installed backwards and the nut was actually blocking access to the clutch drain plug. What you need to do is pull the nut out. Flip the bolt around so that the nut is on the outbound side of bike and reinstall it that way, which will give you clean access to the clutch drain plug.
I just ran into this as well. Swapped the bolt end for end no problem.
